Shifting and A4...any consequences?
Old May 8, 2007 | 05:21 PM
B-rent's Avatar
B-rent
At what speeds should we shift? Cause it seems like 1st and 2nd take forever to get to 4500+ rpms
I dont think doing 60 in 2nd is correct lol
Old May 8, 2007 | 06:39 PM
thegame's Avatar
thegame
I don't know if it's different for Z06's and regular C5 M6's but I know that the first gear in the Z top speed is 50mph , 2nd gear is 70mph, 3rd gear is 100mph, and i forget 4th and 5th are.
Old May 8, 2007 | 07:08 PM
Vette_Fan's Avatar
Vette_Fan
Here's the thing.... While driving in "D", stepping on the gas will take you into 3rd, or 2nd depending on how hard you press, or where's your powerband. THIS will not hurt anything. These cars were made to run this way. Your 2nd gear will take you to 60-70 mph (in a Mn6 & A4). If and when the PCM shift for you, it won't hurt the tranny. However, if you shift manually (all the time), this WILL hurt the tranny. (I was told by a tranny rebuilder who rebuilt a AT tranny for me). But once in a while, if you shift manually to be in a certain gear/powerband, that would be ok though... I stick in into 3rd or 2nd when I'm ready to pass someone in a high traffic situation. Or on the freeway - into 3rd so I dont have to slam on the gas.
Old May 8, 2007 | 08:51 PM
nmbis2k's Avatar
nmbis2k
Since I like to drive the road to Sequoia Nat. Pk., I shift mine alot; both uphill and down.
I also generally baby the car...and have serviced the trans 2X in 25k miles. running a B&M cooler, and Dexron IV ATF.
Yet to any of my transmission fail.
Old May 8, 2007 | 11:40 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Originally Posted by thegame
But isn't RPM's trannys made to take a beating??? If stomping an A4 at 70mph and it kicking into second is optimal for acceleration wouldn't that be ok?? What if the tranny has hardened input and output shafts?
My comments were baised on the conversation I had with RPM concerning MY stock trans. It`s probably best that you call them direct with your question regarding an "built" trans.
All I can tell you is that they (RPM) said I should down-shift from 4th to 3rd before flooring it in order to avoid going from 4th to 2ed which apparently is VERY hard on the trans.
RTR
Old May 9, 2007 | 10:23 AM
yankeevetteconvert's Avatar
yankeevetteconvert
RTR
I have their Level IV trans. and they told me the same thing.
