Shifting and A4...any consequences?
Old May 6, 2007 | 07:22 PM
G8rDMD's Avatar
G8rDMD
National Champs Gators 4 St. Jude '09
St. Jude Donor '10-'11
Default Shifting and A4...any consequences?
I'm sure I'm not alone on this, but sometimes I like to shift my A4 to have more control over gear selection. Especially in a nice series of turns, nothing is more fun than clicking down to 2nd and gunning the motor while exiting... But the question is, does this damage the transmission or shorten its life span? I know, I know, get a manual...I do love a good 6 speed, but hate it in heavy traffic--hence the auto. Opinions? Cold hard facts? I'm all
Old May 6, 2007 | 07:31 PM
C5Dream2004's Avatar
C5Dream2004
Good question, I've wondered the same - I like taking my a4 out of overdrive around town or shift but what does it do to the trans??
Old May 6, 2007 | 10:27 PM
TLewis4095's Avatar
TLewis4095
Hurts nothing. Your just doing manually what the tranny/PCM controll automatically.
Old May 6, 2007 | 10:35 PM
B-rent's Avatar
B-rent
for more responses
Old May 6, 2007 | 10:57 PM
1965imp's Avatar
1965imp
I don't think the A4 will let you down shift if the speed is too high for the gear you want to select...so have at it.
Old May 7, 2007 | 02:23 AM
WetteVette's Avatar
WetteVette
Old May 7, 2007 | 02:32 PM
aleadfoot's Avatar
aleadfoot
I have driven my c4 and now my c5 with A4s for over 100,000 miles and beat the crap out of the trans with shifting. I love it and to date I have had no problems that can be attributed to the manual treatment of the trans. How can you drive without doing this?
Old May 7, 2007 | 05:13 PM
G8rDMD's Avatar
G8rDMD
for the evening crowd...
Old May 7, 2007 | 06:53 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Since I canyon carve with my blown A4 I called RPM with this same question.
Manual shifting is fine, the only thing they told me to avoid is when in overdrive (4th) at freeway speeds (say 70mph) and flooring it causing a down-shift from 4th to 2ed, very hard shock to the trans.
If you want to romp on it hard at that speed RPM said to first downshift into 3rd then romp, much easier on the trans.
Otherwise the only other thing to note is temps, I`d put the largest cooler you can fit, cheap insurance!
Old May 7, 2007 | 07:11 PM
G8rDMD's Avatar
G8rDMD
Thanks for sharing the info...I had no idea about the harm in smashing the gas to shift from 4 to 2...I will definitely avoid that from now on. Where can I get a cooler and how hard is it to install?
Old May 7, 2007 | 10:12 PM
99 vett babycar's Avatar
99 vett babycar
Otherwise the only other thing to note is temps, I`d put the largest cooler you can fit, cheap insurance![/QUOTE]
get a B&M 24K btu cooler, Texas Speed has 'em as well a Suimmit and several supporting vendors
Old May 7, 2007 | 10:36 PM
LMz28's Avatar
LMz28
Cruising
in my manual it says not to shift into first or second while going faster than a certain speed.
Old May 7, 2007 | 10:41 PM
thegame's Avatar
thegame
Old May 7, 2007 | 10:42 PM
thegame's Avatar
thegame
But isn't RPM's trannys made to take a beating??? If stomping an A4 at 70mph and it kicking into second is optimal for acceleration wouldn't that be ok?? What if the tranny has hardened input and output shafts?
Old May 7, 2007 | 11:35 PM
B-rent's Avatar
B-rent
What are the speeds?
I tried this a little bit tonight, the tranny temp climbed to 199 during the first 30 mins but then I hit the highway and after about an hour on the highway not shifting (on cruise control) it was between 196-199
Are those temps alright?
Old May 8, 2007 | 12:08 AM
FRC Jon's Avatar
FRC Jon
As long as you are not overrevving the engine and the tranny doesnt overheat you should be ok
Old May 8, 2007 | 09:16 AM
TLewis4095's Avatar
TLewis4095
Any time you use maximum force on any parts such as the overdrive to 2nd kickdown you are stressing parts to the max. No car is made to take constant stress to parts like that can generate. Just like a high stall convertor is optimal for acceleration, but any time you violently accelerate you are stressing parts. That said, the vettes do handle it pretty good, but it will shorten the life some.
To Shifting and A4...any consequences?
Old May 8, 2007 | 12:34 PM
mickey_7106's Avatar
mickey_7106
when u shift from OD to 3rd do u take your foot of the gas or do you shift when your gaining speed?
Old May 8, 2007 | 01:50 PM
robert123's Avatar
robert123
By the time you shift from od to 3rd then stomp on it you can kiss the race goodbye.
Old May 8, 2007 | 01:53 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It was not to be manually selected then GM would not have a shifter there to manually shift it!
Perhaps by putting it in a gear selected by you while driving in the twisties you actually save the tranny from grunting in the higher gears?
Thanks,Matt
