Racetronix Fuel Pressure?
Old May 8, 2007 | 10:08 AM
HP_Addict's Avatar
HP_Addict
Default Racetronix Fuel Pressure?
I just installed a Racetronix pump, hot wire kit, and 60 lb injectors. My fuel pressure runs about 54 lbs in the morning at cold idle and 50 lbs when warmed up and cruising. My stock pump usually ran about 56-58 lbs. Maybe the Racetronix flows more at a lower pressure, but what pressure does your pump run?
Old May 8, 2007 | 01:08 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
My racetronix pump runs about 65 psi cold and goes down to 63-62 psi hot. Where is your fuel pressure gauge located? Mine is in the fuel rail for these pressures I see.
Old May 8, 2007 | 01:20 PM
LRD VDR's Avatar
LRD VDR
Ditto
Shahram
Old May 8, 2007 | 01:32 PM
HP_Addict's Avatar
HP_Addict
Mine is mounted in the end of the driver fuel rail. Where the shrader valve was. I just wonder if I got a weak pump.
Old May 8, 2007 | 02:19 PM
WKMCD's Avatar
WKMCD
I've got mine set at 58lbs and it stays there.
To Racetronix Fuel Pressure?
