Power steering groan??
Old May 8, 2007 | 05:19 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Default Power steering groan??
Normal or not?:
When I pull into my office garage after ~40 min. commute, as I manuever into a parking space at low/walking speed I notice a bit of a "groan" from the power steering as I'm spinning the steering wheel back and forth. Normal or something to look into?
Power steering fluid level is right where it should be, and the system has never been opened ('04 with <15K on it). No strange feel in the steering wheel.
Thanks for any input!
Mark
Old May 8, 2007 | 07:09 PM
TEXHAWK0's Avatar
TEXHAWK0
If the fluid level is not low, then it could be possible the belt is slipping when the pump is under load.
Old May 8, 2007 | 07:36 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Mine groans ocassionaly if I put it under a load at or near idle rpm.
To Power steering groan??
