dip stick reading
Old May 9, 2007 | 09:14 AM
tin's Avatar
tin
Default dip stick reading
I recently installed headers in my 98 and with that had to change
the dip stick tube to clear the headers , but wen i changed the oil
i could not see any oil in the dip stick , even after 6.5 quarts like
the manual says , has any one had this happen .
Old May 9, 2007 | 09:45 AM
jovette's Avatar
jovette
If you changed the dip stick tube, does that also require purchase and use of a new dip stick as well? ( I really don't know, just asking. )
Old May 9, 2007 | 12:58 PM
The Wrench's Avatar
The Wrench
Yes, a new dip-stick is required. the later model tube and stick is approx 2 inches longer - so you will see no oil on the old stick if inserted into the new tube.
DG
To dip stick reading
