coolant sprays everywhere
Old May 9, 2007 | 09:23 AM
MJD's Avatar
MJD
Default coolant sprays everywhere
I just took my car out for the first time after a cam swap. As I was about to pull into the driveway after a short 10 min drive suddenly I see what I thought was smoke coming from the engine. I kill the engine and jump out to find that I'm losing coolant at either the lower radiator hose or the drain valve. After a minute it quits leaking and I still have some in the surge tank. I did not follow any procedure to refill the coolant after the swap, just filled it to the cold fill mark. Did I overfill the system and that is what caused this? Any help would be great, I'm suppose to have a tune done an hour away thursday and need this thing running ok.
Old May 9, 2007 | 10:37 AM
TEXHAWK0's Avatar
TEXHAWK0
Over filling would not cause a leak at the lower hose or drain.
You need to find out for sure where the leak is before you drive it very far.
When you say you still have coolant in the tank...how much is left?
Is it still to the full mark?
IF the system overpressures, it should relieve at the cap.
Look for a failed hose, or if the drain valve did not get closed all the way.
Old May 9, 2007 | 10:49 AM
MJD's Avatar
MJD
There is probably about a 1/2 inch left in the tank. Last I checked it was not leaking (after sitting overnight). I'll double check the valve when I get home.
Old May 9, 2007 | 12:43 PM
Jim Taylor's Avatar
Jim Taylor
One of the main hoses that goes into the water pump is only supposed to seat half way on the pump flange. After my swap I made the mistake of pushing the hose all the way to the pump body. It didn't leak before I caught the mistake and fixed it.
Old May 9, 2007 | 01:02 PM
jordanfd's Avatar
jordanfd
Not rocket science problem. 1. Raise hood 2.Check water level 3. Start motor 4. Let system presure up 5. Locate leak and repair 6. Da-Da
Old May 9, 2007 | 01:13 PM
MJD's Avatar
MJD
Is the drain valve known to fail and what does it take to replace it, just unscrew and pull out?
Old May 9, 2007 | 10:47 PM
TEXHAWK0's Avatar
TEXHAWK0
It probably quit leaking when the pressure was relieved. As pointed out, you need to refill the reservoir, and run it until the system starts to build pressure, then locate the leak.
I would not think the drain valve would fail unless the pin was broken off while trying to open it. It is just a plug with an o-ring. If you need to remove it, turn it about 1/4 turn until the pin on the plug lines up with the slot in the radiator housing. Then you can wiggle the plug and pull it straight out of the radiator. You should be able to get a replacement at the dealer or a local parts store.
Old May 9, 2007 | 10:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
When you had the front end off, the smaller hose that connects to the throttle body... did you run it under the upper radiator hose or on top of it? If its under, it was laying on the water pump itself and you probably wore right through it. Just one other possibility.
Old May 9, 2007 | 11:30 PM
MJD's Avatar
MJD
I fixed it. The lower radiator hose was almost completely off. When the pressure was up it pushed it off even further and allowed coolant to pour out. I put it back on and added a band clamp for extra credit since its a pain in the *** to get to. Got the car out tonight and went on a nice little cruise. Tune and alignment are tomorrow. Thanks for the help guys!
To coolant sprays everywhere
