Reduced power mode and code ?
Old May 9, 2007 | 02:58 PM
simpleman68's Avatar
simpleman68
Default Reduced power mode and code ?
The other day, went into reduced power mode and threw the following codes. After a quick shutdown/restart all was well again and never came back.
It has done this several times before and usually does it when it has been idling for a period of time.
Any ideas on WTF is going on here?
PCM p2101 h - Control Module Throttle Actuator Position Perf.
TCS c1278 h - TCS Temporarily Inhibited By PCM
HVAC b0361 h - Left Actuator Feedback Short to GND
b0441 h - Left Actuator Out of Range
Scott
p.s. I'm running a 382 stroker with LS2 TB and FAST intake 90/90
Old May 9, 2007 | 06:17 PM
simpleman68
Old May 9, 2007 | 06:37 PM
MUKAK's Avatar
MUKAK
exact same thing happened to me on Sunday.... i restared twice and it was in LIMP mode, on the 3rd try everything was normal
Old May 9, 2007 | 06:38 PM
MrPickles's Avatar
0MrPickles
Former Vendor
Check your ground connections, there are several around the car but the big one is near the battery tray attached to the frame.
Old May 9, 2007 | 11:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds to me like you may have a problem with the Throttle Position sensor OR the gas peddel sensor.
Take a look at the plugs and sensors,
BC
To Reduced power mode and code ?
