Need help removing front tire
Old May 10, 2007 | 09:24 AM
gmbnj's Avatar
gmbnj
Default Need help removing front tire
I was trying to paint my calipers and went to remove the front the wheel for the first time. Bought car a month ago.
Anyway, one of the lugs is stripped!!! What can I do to get it off?
Old May 10, 2007 | 09:47 AM
LightFighter_GXP's Avatar
LightFighter_GXP
chisel, stud is prolly crossthreaded to so , just take it to the wheelshop and have them do it if you don't have the tools
Old May 10, 2007 | 10:01 AM
gmbnj's Avatar
gmbnj
I figured that the stud is probaly cross threaded so I will go to the wheel man.
Ay idea how much it should cost?
Old May 10, 2007 | 10:06 AM
HONDAFIXER's Avatar
HONDAFIXER
Use a drill with progressively bigger bits to drill through the nut and the lug
Old May 10, 2007 | 05:11 PM
SilvaDragon's Avatar
SilvaDragon
All depends on if they want to hit you with the Corvette Tax.
It's about a 1/2 hour job, including banging out the stud and
sticking in a new one.
Old May 10, 2007 | 05:20 PM
AU N EGL's Avatar
AU N EGL
Demil tool with a cutting wheel. Cut the lug nuts off. I have not done this but I know several ppl who have.
Good Luck
Old May 10, 2007 | 08:06 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
If you want to do this yourself, and don't want to ruin your wheel, you will have to drill out the nut and stud. To do this, you should start with a small diameter drill bit( probably around 1/8 or 3/16) and use a center punch to get a dimple on the end of the nut so the bit doesn't "walk "on you. Move up in size until you drill through the nut and can get it off. An easy out may help you pull on it once you get close, or a sears screw extractor, so you can pull on it. I have never done this on a wheel, but I have drilled out screws in other situations. Best advice is to bring it to a wheel shop though IMHO.
Old May 10, 2007 | 09:09 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default REmoving bad lug nuts
There is a set of sockets that you can use to remove lug nuts that are rounded off. When I purchased my '94 it had locking lugs and no key/lug for them.
I went to the corner service station and he had it off in 30 seconds. It was a socket that he hammered onto the lug nut and then just twisted it off. Check with your tire vendors, service stations, etc.
If you can't find anyone with it, PM me and I check with my local service station to see what he used.
BTW, he wants my '72 Coupe, so he's always real nice to me.
Bob K.
To Need help removing front tire
