procedure for Throttle position relearn?
Old May 10, 2007 | 12:06 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default procedure for Throttle position relearn?
I've been getting trouble codes related to my throttle body ever since i had it ported. I was told a throttle position relearn could solve these problems. Anyone know how to fix this?
Old May 10, 2007 | 12:08 PM
Zosickness's Avatar
Zosickness
Old May 10, 2007 | 12:45 PM
Oldvetter's Avatar
Oldvetter
Here you go, from the Shop Manual for a 1997:
Document ID# 407276
1997 Chevrolet/Geo Corvette
Idle Learn Procedure
Anytime the PCM or the battery is disconnected, the PCM looses power, or the PCM is reprogrammed, the PCM's learned idle position is lost. The engine idle is unstable when the learned idle position is lost.
Perform the following procedure in order to return the learned idle to the correct position:
Automatic Transmission
Turn OFF the ignition.
Restore the PCM battery feed.
Turn OFF the A/C controls.
Set the parking brake and block the drive wheels.
Start the engine.
Allow the engine coolant temperature to reach 80°C (176°F)
Shift the transmission selector into the drive range.
Allow the engine to idle for 5 minutes.
Turn ON the A/C controls.
Shift the transmission selector into the park range.
Turn OFF the engine for 30 seconds.
Manual Transmission
Transmission in neutral.
Start the engine.
Document ID# 407276
I assumed that "idle relearn" is what you were looking for. I looked under "Throttle Body Assembly Replacement" and only found the following refering to throttle position:
Check for complete throttle opening and closing positions by operating the accelerator pedal and monitoring the throttle angles using a scan tool. The accelerator pedal should operate freely without binding between full closed throttle and wide open throttle.
Old May 10, 2007 | 02:19 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Thanks.
Old May 10, 2007 | 02:22 PM
EStreeter's Avatar
EStreeter
Who ported the throttle body? I have read articles about the benefits of porting a throttle body on the LSx engine and they all warn not to remove or touch the material at the point where the blade contacts the throat tube. They said this could adversely effect the idle quality and throttle performance.
I just got a ported throttle body from Mark Shaner at S2 Performance. Put it in and the car ran great from the first start up. No problems and no codes. Nice improvement in throttle response too.
Maybe you have a problem with the porting job.
Old May 10, 2007 | 03:47 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Same procedure explained a little differently----C5--
1) turn key on--don't start--
2) remove fuses #16 and #23
3) turn key off
4) re-insert fuses
5) start engine run til coolant is 176 degrees and at least 5 minutes
6) shut off engine and leave off for 1 minute
7) drive car normally--it will now re-learn ide --takes 30-50 miles
Old May 10, 2007 | 04:29 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
shaner did mine too. It's running fine, but the check engine light keeps coming on. i'll try that procedure tomorrow to see if it works.
Old Jul 12, 2023 | 07:11 AM
drumow's Avatar
drumow
Cruising
Hi I repalce throttle Body but get error P0122 does this have to do with Throttle position relearn
Old Jul 12, 2023 | 09:30 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
NO !!…this has to do with “idle relearn” and not TPS relearn…there is no such thing as a TPS relearn……follow instructions I offered you on C6 Tech today.
Old Jul 13, 2023 | 04:31 PM
grinder11's Avatar
grinder11
Hey Rob. Maybe I don't know what I'm talking about, but IIRC the idle relearn procedure is slightly different on an A4 than the manual 6spd. Dont know why, or if it matters. FWIW......
Old Jul 13, 2023 | 06:04 PM
C5 Diag's Avatar
C5 Diag
Hi Mike !!…OP has a 2005 C6 but posted this question in C5 Tech…idle relearn same for manual or auto !!…procedure below.
To procedure for Throttle position relearn?
