ZO6 exhaust installers, need advice....
Old May 11, 2007 | 01:47 PM
BATM4N's Avatar
BATM4N
Default ZO6 exhaust installers, need advice....
I bought some ZO6 exhaust with the bypass, and going to put them on this weekend. I did a search and couldn't come up with anything besides new gaskets that I'll need for this mod. Appreciate any advice on parts I'm missing from someone that has done this Thanks
Old May 11, 2007 | 02:15 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
My memory from last spring is: the gaskets are it.
One recommendation: spray penetrating oil on the four flange bolts the night before. These are not as bad as header studs/nuts, but why take a chance?
Old May 11, 2007 | 07:40 PM
BATM4N's Avatar
BATM4N
Didn't think of that, good idea Dealer sells gaskets for $8 a piece One thread said I might need two for each side
Old May 11, 2007 | 08:26 PM
Crabr1's Avatar
Crabr1
I've reused my gaskets a couple times,haven't noticed any leaks,not sure if I should have used new,but like i said no leaks.
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
You only need one for each side.
Old May 11, 2007 | 10:22 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
My original gaskets worked fine... re-used them with no leaks.
You will need one pair of very large *****, as the car is going to have to be WAAAAAAAAY up in the air (approx. 35")...
Old May 11, 2007 | 11:37 PM
BATM4N's Avatar
BATM4N
HOLY $HIT!!!
Sounds like I'm going to need a lift
Old May 12, 2007 | 12:44 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ZO6 TI exhaust is a direct fit. If the old gaskets are good (most likely) reuse them. Easy install but a lift makes things easier!
If you want to play, do it on the JACK!
The exhaust is EXCELLENT.
BC
Old May 12, 2007 | 12:42 PM
chuck1026's Avatar
chuck1026
HOLY $HIT!!!
You do not need a lift. Just a lot of courage and a good helper. The jack has to be offset to allow the tips to swing down.
My friend "Pitt" came over and helped get the C5 front up on ramps, then helped me align the jack stands when we raised / lowered the car. It would have been a lot easier if I knew to offset the jack so that the handle pointed towards the side of the C5 of the muffler being removed. (Driver side positoning shown in my picture).
Pass side is tighter, so do that first. Then driver side seems EASY.
If you dare to do this, BE CAREFUL AND USE JACK STANDS!!!
Old May 12, 2007 | 01:44 PM
davidfarmer's Avatar
davidfarmer
don't forget to lower the sway bar also. It is easier to do it BEFORE hand, as once you get the exhaust loose, it can be difficult.
No special tools need. 2 wrenches/sockets to disconnec the bolts, and that's pretty much it.
Where did they find titanium tubing for the mod???
Old May 12, 2007 | 05:08 PM
chuck1026's Avatar
chuck1026
Good call! I ended up removing mine temporarily.
Old May 12, 2007 | 06:45 PM
B-rent's Avatar
B-rent
It helped me and my mech to try and instert the exhaust from the rear, but turn the entire thing sideways, get over and around stuff, then turn it like it will be mounted
Old May 12, 2007 | 07:40 PM
legman's Avatar
legman
you got to get her up there to get that right side out, remember, stability is a must if you're not using a lift.....I have LT's / freeflows and x/pipe.......nice and knarly...
Old May 12, 2007 | 07:42 PM
legman's Avatar
legman
HOLY $HIT!!!
nice plate Chuck.....
Old May 12, 2007 | 09:21 PM
GUSTO14's Avatar
GUSTO14
Most good auto parts stores carry Exhaust Gasket material in sheets like this...
For about $10, you can cut out half a dozen gaskets. I keep a few sheets around just for those times when you need to do a job and don't want to chase down a gasket that should sell for a couple of bucks...
Good luck... GUSTO
Old May 13, 2007 | 12:11 AM
BATM4N's Avatar
BATM4N
I want to play and want the sound but don't know if Ihave the ***** to get underneath that
Old May 13, 2007 | 12:15 AM
BATM4N's Avatar
BATM4N
I just changed the sway bars 2 weeks ago
I bought them off of a guy here in San Diego and he had someone do the welding so no idea where he got the tubing from
To ZO6 exhaust installers, need advice....
Old May 13, 2007 | 12:20 AM
BATM4N's Avatar
BATM4N
Sweet!!! I will have the same setup someday. Just have to convince the wife that LT's and x/pipe are not for sound, rather for better gas mileage
Old May 13, 2007 | 12:28 AM
BATM4N's Avatar
BATM4N
Was this easier b/ you had the setback of it not on a lift or you did have it on a lift?
Old May 13, 2007 | 12:32 AM
BATM4N's Avatar
BATM4N
Good luck... GUSTO
Thanks for the heads up on that. Sounds like a much better deal then $8 a gasket.
