Header Install, are new gaskets needed??
Old May 11, 2007 | 05:19 PM
Corvette Don's Avatar
Corvette Don
Default Header Install, are new gaskets needed??
Will I really need new header gaskets and air tube gaskets or are the old ones reuseable?
Old May 11, 2007 | 05:49 PM
ZOsix's Avatar
ZOsix
I just installed my ARH with my old ones and had no leaks
SpeedyZ's Avatar
SpeedyZ
It really depends on which gaskets you have. In a 2000 you probably have the correct gaskets. The gaskets you want have round exhaust port. Starting around 2000-2001 they started using a oval port gasket which may not seal good on headers. I always order gaskets for a 1999 coupe and always get the correct round port gasket. By the way, the factory triple layer steel gaskets are the best header gasket you can get. Don't use those crappy fiber gasket that lots of manufactures ship with their headers. Those fiber gaskets will seal good, for a while....
As far as AIR tube gaskets, it the old ones looks good, I would reuse them. After all they are really easy to change if they ever leak.
Old May 11, 2007 | 06:12 PM
Corvette Don
Good to know, i hope I have the right ones then
To Header Install, are new gaskets needed??
