trans and diff fluids
Old May 11, 2007 | 11:31 PM
wrustywrench's Avatar
wrustywrench
Default trans and diff fluids
I know that this has been aksed many times,,, but I am too lazy to search for it..
how much fluid does the trans and diff hold on the six speed cars
and what is the best ,,,
I should say,, does the majority say go with royal purple....for both??
thanks
Old May 12, 2007 | 09:04 AM
99 vett babycar's Avatar
99 vett babycar
A4 or M6 ??
Old May 12, 2007 | 09:39 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
It would be for an M6 thanks
Old May 12, 2007 | 09:54 AM
striper's Avatar
striper
If you are doing a change on the M6 you'll probably get in approx. 3 1/2 qts. I've tried a few different brands of trans fluids and so far the best for me is the Royal Purple Synchromax. It's a fluid designed for manual trans that require ATF. In the diff I'm running Mobil 1. If I remember correctly 2 qts will do a change. While you are at it, I recommend getting magnetic drain plug replacements. The big Corvette parts houses usually carry them.
Old May 12, 2007 | 10:50 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Youll need:
4 quarts for the trans (probably will take between 3.5-3.75 quarts)
2 quarts for the diffy (probably will take between 15.-1.75 quarts)
Trans needs ATF, diffy needs 75w-90.
I use Amsoil AFT and Amsoil SVG
I also bought two pumps from amsoil to make the fluid changes easy.
Bottom line: amsoil has everything readily available on their website. One stop shop
Old May 12, 2007 | 06:10 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
thanks
Manual Tranny takes about 3.7 quarts
Diff takes about 1.7 quarts
I use and recommend:
Tranny: AMSOIL ATF
Diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
This comes in handy for the DIYer: AMSOIL Hand Pump
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 12, 2007 | 11:32 PM
wrustywrench
well jparr,,,you got your answer,, get your stuff and lets get er done.
oh,, by the way, I had to unload a HUGE load of field stone today,,,,
in a way,,you got me threw it....
Old May 12, 2007 | 11:33 PM
wrustywrench
many thanks guys,,,,,jparr needs to get some lube so we can change his trans and diff lubes.....did his oil and clutch yesterday
To trans and diff fluids
