Too Much Vacuum??
Old May 14, 2007 | 07:57 PM
Vettedreamer2's Avatar
Vettedreamer2
Default Too Much Vacuum??
O.K. I have a 98 coupe. Let me start off by explaining what I installed.
Swapped out stock head for trickflow 215, 7.5 pushrods, harland rockers, SVO 30# injector, New rails and plumbing, Fast 90 w/ls2 ported tb. I also installed abear valve covers with catch can.
I was removing the oil cap with the car idling and I couldn't get the cap to come off, as I pulled harder air started too rush past cap. Put hand over opening and it is like putting your hand over the end of a shop vac hose (after holding it there for a few seconds).
Is this normal on a N/A LS1??
How much vacuum pressure is normal?
Car seems to run fine for not being tuned yet, but I am concerned about the amount of vacuum there is. Is this going to damage anything?? How would I even reduce it in a closed system like this??
Any input would be appreciated. Thanks.
Some pics of setup.
Old May 14, 2007 | 10:09 PM
TYSON1997's Avatar
TYSON1997
Get a bigger camshaft that ll get rid of some of that extra vacuum. Seriously though how big is your pvc line. And does it have a fresh air vent?
Old May 15, 2007 | 02:21 AM
Vettedreamer2
I have a big cam. lgx3 23x/23x .601/.609.
Pvc line is -6 and no fresh air, was told not to put unregulated air flow in system
Old May 15, 2007 | 07:20 AM
see5's Avatar
see5
Sounds strange.
Your intake manifold vac should be contained in the manifold, why you would have that much in the block is odd.
Old May 15, 2007 | 08:32 AM
Tomulrich's Avatar
Tomulrich
you need a fresh air line..or a breather......that is why you are making vacuum.....if you pull air from a source and have no new air to replace it you will then be pulling a vacuum
Tom
Old May 15, 2007 | 09:22 AM
FRCTony's Avatar
FRCTony
Tom
Time to pull the covers and start drilling.
Old May 15, 2007 | 07:10 PM
Vettedreamer2
Hi dumbass here.
When I added the LS2 tb it does not have a air feed for crank system, so I had on incoming air (hence my new nickname).
I tapped into the air bridge (after the MAF) too pull the fresh air in. It is not recommended to just put a breather on as that air has not been accounted for by the Pcm.
Thanks J
Old May 15, 2007 | 09:16 PM
FRCTony's Avatar
FRCTony
Originally Posted by Vettedreamer2
Hi dumbass here.
Thanks J
I'm not familiar with the LS2, but the air is metered by the PCV no?
Shouldn't matter how many vents you have.
Further, the PCM is gonna get tuned anyway.
Old May 16, 2007 | 12:59 PM
see5's Avatar
see5
I would suggest you install a vented catch can with a restricted bleed line only, to the intake.
LS2s, particularly strokers, under decell are inducing pressre in the block.
To Too Much Vacuum??
