Idle problem
Old May 14, 2007 | 08:13 PM
JPCCDD's Avatar
JPCCDD
Default Idle problem
Hey all. Couldn't find a thread about this so I guess its not common. When i let push the clutch in and let the rpms drop from over 1500 all the way down, they drop to about 400, and then pop back up to 600 to 800. and bounce around in that gap. i was thinking vacuum leak but couldn't see or hear one. it also sets off my check gauges light momentarily and sets off my charge system fault on the DIC that stays on. Whats causing this? Its making driving in traffic annoying cause it keeps setting off warnings. And its not intermittent. It happens all the time.
Old May 14, 2007 | 08:27 PM
Vettedreamer2's Avatar
Vettedreamer2
Did you recently have the battery disconnected for a period of time??
If yes, may have to do idle relearn (do search)
If no, check very throughly all hoses to intake an make sure none have come disconnected to rotted out.
Old May 14, 2007 | 08:32 PM
JPCCDD's Avatar
JPCCDD
thanks i'll give that a try.
Old May 14, 2007 | 08:45 PM
JPCCDD's Avatar
JPCCDD
worked like a charm. thanks dreamer.
To Idle problem
