Mirror Issue
Old May 6, 2007 | 06:40 PM
RREDTOY's Avatar
RREDTOY
Default Mirror Issue
Bumper in to exterior mirror ...now it swivels and I can pull it up. It will not stay in position. Need input.
Old guy needs help
Old May 6, 2007 | 10:46 PM
corvettedoug's Avatar
corvettedoug
Is it the mirror inside the housing that is loose?
If so you might have broken the plastic snaps on the mirror motor. I would try to snap it back in to place and see if it stays. Otherwise you can pop the mirror out and check what the motor looks like.
Old May 6, 2007 | 11:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you mean that the entire mirror housing is loose or just the glass it self?
BC
Old May 14, 2007 | 06:45 PM
jedblanks's Avatar
jedblanks
Have same problem -- entire mirror housing loose.
Old May 14, 2007 | 09:11 PM
cruisemon's Avatar
cruisemon
There is a belleville spring washer that holds the mirror on a pot metal post and retains a spring that loads the mirror to hold it place when it is rotated on the base. The spring washer comes loose and the spring loses tension. Search the thread for a repair. Altenrative is a $400 mirror.
Charlie
To Mirror Issue
