Spec 3 + clutch......
Old May 16, 2007 | 07:48 AM
lodilobo's Avatar
lodilobo
Default Spec 3 + clutch......
I have this problem with shifting...mostly from 1st to 2nd since installing the following mods on my '99 FRC...LS6 cam, LS6 heads, Fast intake, long tube hdrs. w x pipe and tit. exhaust, Vortech supercharger, 42 lb. injectors. I also installed a new B&M Ripper. The car shifts fine unless you are on it hard and attempting to power shift. I am not "missing" 2nd, but it just will not shift smoothly at test and tune. Could it be that this Spec 3 + clutch is not enough for the 574swhp - 515 rwtq ? I am thinking trans. problems or clutch.....anyone care to make a guess? Also...I forgot to mention....aluminum flywheel.
