manual C5 Fan switch wiring
Old May 16, 2007 | 08:30 AM
Tomulrich's Avatar
Tomulrich
Default manual C5 Fan switch wiring
anyone set up a manual turn on for the cooling fans? I want mine to turn on in the stock configuration but I want to be able to flip a switch and have both fans turn on high....
Let me know if you have any links or info. Please make it specific to the C5 Corvette.....I have seen the schematics people made on the other forums and online....they dont help.....I want to know what wires to hokk where on the C5
Tom Ulrich
Old May 16, 2007 | 08:55 AM
neile's Avatar
neile
CI 3-5-8 Veteran
Default Use the airconditioning switch
I looked into this and drew up a schematic with two relays. The issue is the fans are controlled by one of the modules and you will set codes (and possibly damage the controller) if you just wire around the existing circuit.
Anyway, you achieve nearly the same control by flipping on the air conditioning which bring both fans on.
Neil
Old May 16, 2007 | 09:12 AM
steve badalamenti's Avatar
steve badalamenti
All you need to do is:
1) Go under the hood, and in the relay / fuse box locate RELAY # 43. Remove the relay. On it's underside, you will see numbers that denote the individual pin numbers.
2) Stab a wire in the socket for PIN # 86, replace the relay, run the wire inside the car, add a TOGGLE SWITCH , and connect the other end of the wire to GROUND.
I've been using this for 2 years now.
Old May 16, 2007 | 01:21 PM
THXBABY's Avatar
THXBABY
Cruise-In II Veteran
Default Manual Fan Switch
Tom
I added a manual switch to my 2001. To do it you need a switch and 3 relays.
I have a drawing at home and if you are interested I could scan and email it to you.
I think the cost for the relays and switch was about $10 or $12. I mounted the relays
under the fuse box under the hood. Thats where most of the wiring needs to be done.
The switch is mounted next to the lighter so it is out of sight. The reason for three relays is so that you can ether turn the fans on high or low speed. Before I installed the control we were on vacation and got cought in traffic in Gattlenburg TN. The water temp went to about 235 before the fans came on. The next morning I checked the oil and it was down 1 QT. Never have I had to add oil before.Now when I get in traffic I turn the fans on low and the temp will stay 194-198 and the oil level is good.
Jim
Old May 17, 2007 | 03:41 PM
robert123's Avatar
robert123
Does the car throw diagnostic codes with the switch? Mine did.
Old May 17, 2007 | 04:28 PM
THXBABY's Avatar
THXBABY
robert123
No codes! If you just use a switch to apply power to the coil of the relay you will
get a code. On the C4 the fans were controled by a temp switch so we could just add
a switch to trun the power on and off.The C5 is controled by the PCM so when you
put 12 volts on the relay coil you get a code. The way around that is to use a relay. I
used a 3 standard 12 VDC SPDT relays, 1 SPDT switch, and a few feet of wire. It
took the better part of a Saturday afternoon.
Jim
Old May 19, 2007 | 12:57 AM
Cscokd's Avatar
Cscokd
email me and I'll send you a wiring diagram with details where to tie into your under hood wiring fuse block using a single switch to turn on your fans with the ignition key OFF. I've been using this config for track events, no codes or issues. If you want to turn on both fans, it's a bit more complicated and beware the current draw is 22 amps on high and 11 amps on low. Don't leave the switch on too long or you'll have battery issues.
John
cscokd@gmail.com
Old Jun 21, 2016 | 01:43 AM
02c5blue's Avatar
02c5blue
1st Gear
Default Hi id like to see the drawing
Id like to see the drawing pls e mail me at selfmade3420@gmail.com thanks
Jim[/QUOTE]
Old Jun 21, 2016 | 10:38 AM
73Corvette's Avatar
73Corvette
Your reply is to a 9 year old post ... not sure you saw that
Old May 25, 2020 | 01:10 AM
Jeremiah Todden's Avatar
Jeremiah Todden
8th Gear
Hi Jim, my name’s Jeremiah and I’m from Des Moines. Could you send me a schematic of your cooling fan switch? My 99 vert Is doing the same thing. Thank you
Old May 25, 2020 | 09:18 AM
bjones7131's Avatar
bjones7131
saccitycorvette.com I had this on my previous 01 coupe, worked great and installed in 5 min. Allows you to turn on fan with a fob.
Old May 25, 2020 | 10:06 AM
Jeremiah Todden
8th Gear
Thank you sir.
Old May 26, 2020 | 01:04 AM
SkinS's Avatar
SkinS
Jim
Thanks - I am considering the option.
73 Corvette - This board is a living document used by many over many years. Discussion items seldom go out of relativity.
Old Sep 13, 2020 | 05:47 AM
striped91's Avatar
striped91
The Coolit turns on only the passenger side fan. Like the OP says, he wants both fans to operate in high speed mode.
To manual C5 Fan switch wiring
