Patriot 243 heads standing by
Old May 18, 2007 | 12:23 AM
SLPRC5's Avatar
SLPRC5
Default Patriot 243 heads standing by
I have had these Pat heads since Feb standing by to be installed. They are CNC ported and mill 62cc chambers. The holdup is waiting for Cadillac Racing Lifters to arrive from back order.
I sure hope the wait is worth it.
Here are some pictures of the heads.
Old May 18, 2007 | 01:03 AM
spiral04's Avatar
spiral04
If you ordered them from Scoggins Dickey, I received mine today!
Old May 18, 2007 | 02:34 AM
SLPRC5's Avatar
SLPRC5
Yes I did..........so you give me hope
Old May 18, 2007 | 09:47 AM
Icetech's Avatar
Icetech
Those are the same heads i ordered.. the wait is killin me
Old May 18, 2007 | 09:57 AM
kilrb's Avatar
kilrb
Sleeper, what lift and LSA are you running on the 224? I'll be interested to see your dyno graph after you get her back together and tuned. I'm running the TSP 224R (.581 lift/112LSA) with 5.3 heads. It will be nice to see what #'s you get with the Patriot (LS6's?) heads. Keep us posted!
Old May 18, 2007 | 10:23 AM
FRC Rob's Avatar
FRC Rob
Those are great heads I installed my Patriot 243 heads with 62cc chambers back in December with stock lifters and a little Comp XER 224/228 111 +2 cam and I'm loving 'em.
Old May 18, 2007 | 11:02 AM
vettenuts's Avatar
vettenuts
Crane has out a new lifter, maybe they are more readily available. Or you could always come to the dark side and use the Morels
Old May 18, 2007 | 11:58 AM
02gt350's Avatar
02gt350
I just bought some myslef. It will have a 224/224 .581 112+4 comp. anyone have dyno results from this?
Old May 18, 2007 | 05:46 PM
SLPRC5's Avatar
SLPRC5
My cam is a comp 224/224 .567 .567 lift on a LSA 114. I'll be happy to post the dyno numbers when it's all together.
Old May 18, 2007 | 05:49 PM
SLPRC5's Avatar
SLPRC5
I was pretty close to canceling the caddy lifters and ordering a set of Morels when I was told by SDPC that the caddy lifters were on their way to them...The Crane and the Morels are a lot more in cost.
The wait BETTER be wort it.
Old May 18, 2007 | 05:50 PM
SLPRC5's Avatar
SLPRC5
Great to hear. Do you have any numbers?
Thanks...
Old May 18, 2007 | 06:56 PM
FRC Rob's Avatar
FRC Rob
Thanks...
Never been on a dyno.
Old May 18, 2007 | 07:20 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Thanks...
His car runs like a raped ape. Mid to low 11's all day long.
Old May 18, 2007 | 09:41 PM
SLPRC5's Avatar
SLPRC5
WOW!! Great news to hear
Old May 18, 2007 | 09:54 PM
fotoboy's Avatar
fotoboy
I have the ls6 style heads, how are these differnt? they seem to flow the about the same. BTW heres my car: blk corvette, 2nd car down, http://www.patriot-performance.com/w...05135&DID=1225
Old May 18, 2007 | 10:46 PM
FRC Rob's Avatar
FRC Rob
Thanks Bob...let's just call it a solid mid 11 car for now; at least 'til the new rubber gets here.
Fotoboy,
Nice car. Do you ever drag race it? Any times?
Patriot's flagship LS6 "style" heads start out as raw GM 035 (6L truck) castings. These heads have the same runner design as the LS6 heads, thus the LS6 "style" designation. Patriot welds up & machines the chambers to your desired cc and installs bigger aftermarket valves.
Their 243 heads start out as GM 243 (LS2 and LS6) castings. They don't have any chamber work and use stock GM non-sodium filled valves. These are less expensive, but they still perform great.
Old May 19, 2007 | 03:26 AM
SLPRC5's Avatar
SLPRC5
Here is the flow chart for my heads done by Patriot.
Old May 20, 2007 | 02:56 PM
SLPRC5's Avatar
SLPRC5
bump.....
Old May 20, 2007 | 08:23 PM
kilrb's Avatar
kilrb
I have a 224/224 .581 on a 112. I have 5.3 liter stage 2.5 heads from Texas Speed. With all the bolt ons, I'm at 410whp/390tq, which is about 93whp above stock + Vararam. You can search for posts I have started to find my dyno graph. Don't know if you'll get different #'s with the 241 heads or not, but I'd guess it will be comparable. The low-end with this setup is very, very, very nice! Be sure to post your results when you get it on a dyno.
To Patriot 243 heads standing by
