cleaning transparent targa top
Old May 18, 2007 | 11:09 AM
robert123's Avatar
robert123
Default cleaning transparent targa top
What do you guys clean your transparent targa tops with? Is windex too harsh? I have some sap on it.
Old May 18, 2007 | 12:46 PM
Oldvetter's Avatar
Oldvetter
Don't use anything with ammonia in it. Car wash soap and water. You can wax it.
Old May 18, 2007 | 01:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Stoner's invisible glass
Old May 18, 2007 | 08:11 PM
ciscomatt99's Avatar
ciscomatt99
1st Gear
Stoners is the best.. for anything glass
Old May 18, 2007 | 08:19 PM
YeloFevr's Avatar
YeloFevr
Stoner's + Newspaper
Old May 18, 2007 | 10:04 PM
Dave68's Avatar
Dave68
Your safest bet is to wash the top with the same car wash stuff you use to wash your car. Treat it like paint (including a protective wax/polish) and it will be happy. There is a new Windex that does not contain ammonia, but I would still shy away from anything that is for glass cleaning.
Old May 18, 2007 | 11:14 PM
spiral04's Avatar
spiral04
I don't know if it's best, but I use Plexus, a plastic polish that I use on my GSXR.
Old May 19, 2007 | 09:42 AM
screw991le's Avatar
screw991le
The top is actually Lexan, not glass. Stoner's is for all glass and plastic surfaces. It does not have ammonia which can discolor tint.
Old May 19, 2007 | 01:36 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Too bad the top is not glass. It is Lexan, Plexus is made to clean Lexan, i like it much better then Stoner's, and i have used both.
Old May 19, 2007 | 01:58 PM
screw991le's Avatar
screw991le
I also put a coat of Zaino Z2 from time to time.
Old May 19, 2007 | 05:09 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Do NOT use Windex! It might be ok to try clay bar to remove the sap.
To cleaning transparent targa top
