tire presure reset ?
Old May 18, 2007 | 02:23 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default tire presure reset ?
how do you reset the tire presuring system i know you need a magnet. but what do you do.
Old May 18, 2007 | 03:16 PM
c5chris1999's Avatar
c5chris1999
Navigator
Turn the ignition to ON.
Press the RESET button in order to clear any IPC display warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the DIC RESET button for 3 seconds.
Press the OPTIONS button again until the TIRE TRAINING message appears. NOTICE: If the TIRE TRAINING message cannot be displayed, and the IPC is functioning properly, check if the BCM is configured with the correct RPO codes. Refer to BCM Programming/RPO Configuration in Body Control Systems.
Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
Install the J 41760 Tire Pressure Monitor (TPM) System Programming Tool over the left front valve stem.
The horn will sound, indicating the left front TPM sensor is programmed. NOTICE: If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool. This procedure may have to be attempted up to three times in some instances. When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
LEARN R FRONT TIRE
LEARN R REAR TIRE
LEARN L REAR TIRE
Old May 18, 2007 | 03:20 PM
BlackZ06's Avatar
BlackZ06
Instructions in Tech Tips also ...
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old May 18, 2007 | 04:22 PM
Carbotech Adam
Supporting Vendor
thanks for your help guys!!!!!!!!!!!!!
To tire presure reset ?
