help hosing out radiator debris
Old May 18, 2007 | 08:15 AM
Wayne's World's Avatar
Wayne's World
Default help hosing out radiator debris
I read the recent posts about the Vette being a bottom feeder.
Sucking up grass,pine needles, ect. and getting quite a cache saved up between the condenser and radiator.
Last night I took off the shroud that cavers the top of them and I can see some debris through the small air space between them.
MY QUESTION: How do I back flush them with a hose with the fans and fan shrouds in the way?
I think that back flush means shooting the water through from rear to front but see no way to it.
Thanks in advance for your help.
Old May 18, 2007 | 09:04 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I just used my air compressor on mine. I removed the air cleaner, and the radiator cover (caution fan plastic cover) to expose both the radiator and the condensor.
Once removed I covered the Throttle body opening (used Saran Wrap Press and seal, worked great)
There is a space of about 1 1/2 inches between the radiator and the condensor. You wouldn't believe all the crap between the two of them.
I have a 3/8" extension pipe (copper) made for my compressor and its got a 90 degree bend and about 18 " long.
I use it between the rad and the cond then put it down between the fan bank and the radiator. The sand and stones just rain out.
I have a similar pipe made for my garden hose 1/2" and fanned out at the end and do the same thing. Again more crap comes out. It takes time, but I've been running on the average of 4 degrees cooler on both the coolant and A4 tranny temp. Sounds cumbersom but it works.
Old May 18, 2007 | 10:40 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
Old May 18, 2007 | 11:32 AM
Wayne's World
Thanks.
I see that a special tool is needed for hose or compressed air.
I guess I can rig something.
Old May 18, 2007 | 12:21 PM
AU N EGL's Avatar
AU N EGL
I use an air compressor with a long thin metal wand to get up or down and between the radiator and Compressor.
I also made a wire extension to a baby bottle brush too. That way I can also push the baby bottle brush up between the radiator and condensor. This also pulls out lots of grass.
Old May 18, 2007 | 12:59 PM
Wayne's World
A baby bottle brush on a long handle, good idea!
Old May 18, 2007 | 01:03 PM
Max Grip's Avatar
Max Grip
Be sure to be careful with the hose or the compressed air. Use too much force and you'll bend some fins. My .02
Old May 18, 2007 | 01:12 PM
AU N EGL's Avatar
AU N EGL
Just rember it not to clean the infents ( kids or grand kids ) bottles with the brush after.
Just like dont put the kitty litter back into the cats box after you soaked up the spilled oil on your garage floor.
Old May 18, 2007 | 02:06 PM
T VETTE's Avatar
T VETTE
I lifted up the front a little, got under and used a shop vac with a long brush to loosen up the junk. I think I used one of those long refrigerator ones. I also loosened up the fan shroud to push some of it down. Got 99% of it out.
Old May 18, 2007 | 04:00 PM
96cobrakid's Avatar
96cobrakid
I thought it was a waste of time to do pictures, but here is how I did mine a few days ago....;.
http://www.z06vette.com/forums/showthread.php?t=107783
Old May 18, 2007 | 04:34 PM
Wayne's World
Great documentation, very good job with the pics too!! Directions even I can follow.
This should be put in the Tech Tips.page
To help hosing out radiator debris
