Rear license plate
Old May 18, 2007 | 03:03 PM
ohonepewter's Avatar
ohonepewter
Default Rear license plate
After 7 years of ownership the state of Florida has sent me a new license tag. Now I forget how to remove the black plastic frame. Can someone help me before I break something? Thanks.
Old May 18, 2007 | 04:06 PM
Timbrr's Avatar
Timbrr
Default Removing the rear license plate
Just did this a couple days ago. If you look on the inside edge of the plate holder you will see (4) slots. Be careful and put a screw driver in those slots and pry gently. There are (4) clips with an edge on them that need to pop loose. Once you get one loose you will see what I mean. When you install your plate be sure and put plate in the plate holder and snap back into place before attaching the screws.
