Clicking sound when braking
Old May 18, 2007 | 08:35 PM
JanMan99's Avatar
JanMan99
Default Clicking sound when braking
My 2000 C5 coupe makes a clicking sound at very low speed (like turning while in a parking lot) when applying the brakes. If I do not apply brake pressure while turning right/left, no clicking, only braking. Thought I would post before a repair shop wants to go deep in my pockets. Car has 17,750 original miles.
Old May 18, 2007 | 10:31 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
It almost sounds like the worn out brake indicators, although at those miles it probably shouldn't be, but I would check.
Old May 19, 2007 | 01:49 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Is it multiple clicks? Or just 1 or 2 click as soon as you apply the brakes? If its the latter of the 2, then its your rear axle splines needing a good lube.
Old May 19, 2007 | 04:33 PM
JanMan99's Avatar
JanMan99
Thanks guys for the comments. The clicking is continuous at low speeds if you apply brake pedal pressure. No noise if you turn left/right and keep your foot off the brake ?????????? It definitely comes from the front of the car. Otherwise, goes straight, stops straight, etc.
Old May 19, 2007 | 04:34 PM
JanMan99's Avatar
JanMan99
ttt
To Clicking sound when braking
