problem!!! "REDUCE ENGINE SPEED"
HELP HELP!!
My 98 vette wont dirve, the idle is ruff and the computer is telling me "REDUCE ENGINE SPEED" what does this mean? does anybody know what to do?
Early 97 and 98 C5's had known TAC module issues. It will cause the car to do what yours is doing. Tere is a TSB that explains the problems and what DTC you will see. My 98 (one of the early ones) had the problem bad!!!!
It was so bad I was afraid to drive the car any distance from home.
It was so un-reliable and stranded me so many times that I was ready to burn the sucker.
Here are all the things that I did to bring it back to life:
Replace the TAC module with a 99+ module Approx $230.
Clean the grounds. FREE!!!!!
Replace the old dieing battery. $130. Optima red top
Once The grounds were clean and the TAC module was replaced, she ran like NEW!!
The new battery took care of all the FOB sync and memory loss problems I was also having.
The Throttle Acutation Control ( TAC ) module is a black plastic box located in the passengers fender well on the out side of the PCM:
Read your DTC's
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too!
Then clean your grounds!!!
http://forums.corvetteforum.com/showthread.php?t=896875
BC
That is the rolling frame at the Bowling Green Corvette museaum!!BC
with BC...from his advice previously I replaced my TAC and problem was fixed. Although my reduce engine speed and ABS service light didn't come on often..it still came on so before a trip I replaced the TAC.Thanks BC for the sound advice as always
I pulled codes and they are:
P1220 H
P1221 H
P1515 H
P1571 H C
C1255 H
C1278 H
B2723H
U1064H
I see the codes for throttle position sensor, could that be a result of bad TAC ?
I also couldn't find a definition for code P1571. This concerns me most since it is current.
Any help would be appreciated. Thanks again!
what do you suggest I do, to find out what code I have?
I am thinking of just replacing TAC. so, when I go purchase this I just ask for a TAC year 99 and up. right? I feel so dumb when it comes to electrical parts
go to ... http://www.corvettedoctor.com/Code_Main.html
as he listed and it shows how to read the codes ... all you need is your ignition key to put the car in "RUN" mode ....
Helps if you read what Bill is telling ya .....
once again ALL OF YOU GUYS ARE THE BEST!!!
http://www.gearchatter.com/viewforum40.php
Good luck with it
BTW, thanks for the ground/splice pack cleaning instructions! Completed, but still get this problem...thanks much!
