Transmission/ DTE brace/ fluids ???
Old May 19, 2007 | 07:57 PM
RED99's Avatar
RED99
Default Transmission/ DTE brace/ fluids ???
#1 First, what the heck is this? (See pic). It is from the over-flow hose on the tranny. But I didn't notice anything connected to it. But it looks too clean to have not been connected to anything.
#2 I have 3 of the 4 struts on the DTE brace preloaded. Is it OK to leave the bottom driver side loose until I get the tranny in and fluid in?
#3 Is Synthetic fluids good to use in a tranny and differential. Or should I just use plain regular fluids? The tranny is a fully built level 5 tranny. (If that matters on the clutches)
Old May 19, 2007 | 11:23 PM
94legaleagle's Avatar
94legaleagle
#1 - I believe that is a breather line for the tranny that is not connected to anything - leave it loose as it is -it is OK
#2 - Yes, you have to leave the 4th brace loose, B/C you can't fill the tranny w/ fluid IF the brace is in place
#3 - Dexron III is the correct tranny fluid - I don't know if they make a SYNTHETIC Dexron III - for rear differential, Synthetic lube is recommended.
94legaleagle
Old May 20, 2007 | 12:12 PM
RED99's Avatar
RED99
I was thinking of the Royal Purple synthetic tranny fluid, and the royal purple synthetic 75/90 gear lube.
Has anyone run the Mobile 1 synthetic tranny fluid? I am just wondering if synthetic makes the clutches slip?
Old May 20, 2007 | 12:19 PM
vettenuts's Avatar
vettenuts
If this is a DTE Stage V, you will instantly void your warranty with the incorrect fluid. My Stage IV requires Redline 75W-140 with extra limited slip lube per the DTE instructions. I would call Phil tomorrow, don't put anything in the rear until you speak with Phil. I don't have a Stage V so I don't know if anything is different.
As for the arms, I would leave them all loose until you get it in place if you can't get all of them now. Don't only tighten three.
Old May 21, 2007 | 12:02 AM
RED99's Avatar
RED99
No it's not a DTE stage 5 differential.
To Transmission/ DTE brace/ fluids ???
