From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Ls6 Intake Swap - Will I Notice Difference??
I have a LS6 intake for my 98 Pace car. I was wondering if it is worth swapping now before I do my cam, heads and headers over the winter. I am wondering if my 1/4 mile times will improve? If they will only improve by a small persent or if that, I will not do the swap now.
What I have done to the Pace Car: Thermostat, reprogram, 3,600 converter, Factory 3:15 gears, after market mufflers and a Vara Ram. My best ET to date is 12.62 @ 108.91mph.
I understand that this is just an intake, But I am wondering if the stock intake is such a restriction that this wake it up or just a minor improvement.
I have a LS6 intake for my 98 Pace car. I was wondering if it is worth swapping now before I do my cam, heads and headers over the winter. I am wondering if my 1/4 mile times will improve? If they will only improve by a small persent or if that, I will not do the swap now. What I have done to the Pace Car: Thermostat, reprogram, 3,600 converter, Factory 3:15 gears, after market mufflers and a Vara Ram. My best ET to date is 12.62 @ 108.91mph.I understand that this is just an intake, But I am wondering if the stock intake is such a restriction that this wake it up or just a minor improvement.Thanks,No Trailer Queen Here!!
If you are the kind of guy who enjoys replacing the intake manifold twice do it now. You will definitely pickup 5 to 10 hp and if you go to the same track under the same conditions you might pickup a tenth and a mph. But if it was me I would wait until winter and do it all.
Bah, it's super easy, just do it now and enjoy a few added ponies. You probably won't feel anything from that alone, but I personally can't leave a mod laying around and not put it on.
Thanks Guys, I think I will tackle this on Saturday. I never removed an intake on a Vette. It looks easy. I am actually (Dont Shoot Me) A FORD man. I know FORDS inside and out and by looking at this intake, It appears to be a simple job.
I guess if I can swing an engine in an hour from my Mustang, An intake should be a joke.
I'll keep yo uposted to let you know how I made out. I see that there are rubber gaskets and no water jackets. At least I dont have to change the oil when I am completed.
The 2 back bolts you have to hold up and slide the intake forward alittle.I used a small vise grips to hold one up.The other one you can hold by hand.Piece a cake Rob ................Paul
Is there any way to tell if you have an LS6 manifold without removing it. Former owner is pretty sure that's what's on there, but not positive. I'm going to do some mods this winter and don't want to remove it if I don't have to.
No C5 intakes LS1 or LS6 had EGR. I'm sure someone can post the part # of the LS6 to tell for sure. If it has been swapped for an LS6 then the rear coolant passages on the heads will have plugs in them, rather than a tube to connect to the front coolant lines. Even if the plugs are in place, an LS1 intake could have been swapped back. The part # is the only sure indicator.
OK, Back up. I heard about this before. If I install an LS6 intake - There is a coolant line I have to purchase? I need to know so I dont start this project without all the parts.
The two bolts are unable to be removed with the intake on the engine? Not enough room to pull them out? I only glanced at the intake, I have not looked closely at it to see the details of the job. I love surprises.
The pre'01 Vette had the LS1 intake and devloped 345 crank HP
The '01 and newer Vette had the LS6 intake AND a more slightly aggressive cam profileand produced 350 crank HP....
Explain how changing and LS1 to LS6 intake alone should generate 10 extra crank HP.
No... your stock tubes will work find if you grind down the ribs on the bottom of the LS6 intake, look and you will see what I mean.
Nope, they hit the cowl. Back them out all the way, take the front 8 bolts out, and use one hand to lift the rear of the intake and hold the bolts up at the same time. It's super easy.
You can tell an Ls1 from an LS6 intake by the casting mark on the 1st runner closest to the intake. If it is curved it is a LS6 and if it is a 90 degree angle it is a Ls1. I would look on a few 01+ cars to verify as I may have it backwards.
