Z06 Exhaust System
Old May 20, 2007 | 05:37 PM
manziman's Avatar
manziman
Navigator
Default Z06 Exhaust System
Any secrets I need to know about replacing the exhaust on a stock C5 with a Z06 C5 system. I've been told it's pretty straight forward, but this is my first time and I don't want to end up with a disaster.
Old May 20, 2007 | 05:40 PM
bb609's Avatar
bb609
Edit - 4 bolts, 8 nuts, and 2 exhaust flanges later and you're done as long as the car is high enough off the ground. Best to find someone with a lift.
Here's a tip - the rear brackets mount to studs that are hung through the body. Once you drop the bracket, they hang loose and can be pushed (too easily) back up through the hole. If this happens, pop out a tail light to retrieve and replace it back in the hole.
Old May 20, 2007 | 06:02 PM
01vetter's Avatar
01vetter
You will need to drop the rear sway bar. Just undo the brackets. No need to take of the end links. I think the torque for the sway bar backets is 45 ft-lbs, but you should check.
To Z06 Exhaust System
