Tranny/Diff Leak
Old May 20, 2007 | 07:56 PM
Neeko's Avatar
Neeko
Default Tranny/Diff Leak
Im getting a small puddle at the back of the car so i get her up and notice its dripping from where the tranny meets the rear. Its a dark fluid, almost purple like. Gear oil? Is this a big job to fix? Would love to DIY it if possible. Thanks guys.
Old May 20, 2007 | 08:01 PM
nmbsun's Avatar
nmbsun
Welcome to the "Leaky Butt Corvette C5 Club" !
I have had my 04 C5 fixed twice for rear end leaking.
Hope yours is still under warranty. They are now using a special red sealent that is suppose to fix the problem. I know that the tech took most of the day to fix mine so I really have no idea how a DIY job would go. Good luck.........
Old May 20, 2007 | 08:38 PM
rubyjames's Avatar
rubyjames
Default Leaky butt
I do believe it is coming from the output shaft seal where the diff mates to the trans. I just replace the trans and had to switch over the diff to the new trans.
3 guys, one garage and about 3.5 hours. It is relatively simple, there are a lot of little things to do that fill up the time. I can tell you step by step if needed.
Good luck.
Old May 20, 2007 | 10:45 PM
Neeko's Avatar
Neeko
i'd love a step by step. I have a couple friends who know their way around cars and engines so i'm sure with some direction we could get it done. I would just have to supply the beer. Thanks for the help.
Old May 21, 2007 | 03:14 PM
FL_Dave's Avatar
FL_Dave
I don't really have a step-by-step, but do have a few suggestions. Use brake cleaner to spray down the trans & differential. Once it is clean, it will become obvious where the leak is.
There are plenty of posts with instructions and pictures removing the leaky butt. Do a search.
Replace the other seals while you are in there, especially the diff axle cover seals (known for leaking) and the diff main input seal. Also replace the fuel filter -- since it's handy.
When replacing the diff axle cover seals, use anaerobic sealant (drys w/o air). You can get this at NAPA. Pay a little more for the cleaner/activator. Anerobic sealant will handle a gap of a few thousandths w/o the activator, but is 3-4x as good w/ the activator.
Enjoy
Old May 21, 2007 | 09:41 PM
Neeko's Avatar
Neeko
I had the driver side rear seal changed a few years ago. The other side is holding up ok. This leak is definitely from where the diff meets the tranny. Do i have to drop the rear to fix this? Just don't want to bring it to the shop if i don't have to. Thanks guys.
Old May 21, 2007 | 09:57 PM
chicks-dig-it's Avatar
chicks-dig-it
2nd Gear
Just curious: How many miles do you have on it?
Good luck on the DIY.
Old May 21, 2007 | 11:16 PM
cjcvette's Avatar
cjcvette
There is another option. There was someone who separated the transmission from the diff slightly, cleaned the gap with brake cleaner and then sucked sealant into the gap using a vacuum attached to the transmission fluid fill hole. Sounds , huh? A search will yield more information on this method.
I currently have the exact same leak as you. What I can't find is more information on is how successful the above method is. Who has given it a try, and how did it hold up?
Old May 22, 2007 | 08:58 AM
Nyvetteguy007's Avatar
Nyvetteguy007
You guys are talking about 6spds yes?
Prior to me getting 4.10's installed a month or so ago I did a DIY quick fix that lasted over a year for the leak at the tail end of the trans...I also had the leak in the diff at two places...one on the R/S cover and another in the casing itself...
for the Diff, I lived with it (as I knew I was going to get 4.10's in a while), I always made sure I always had enought fluid in the diff by checking periodically prior to the repair, now no leak as I had the diff swapped by Chuck at Corvettes of Westchester...while he was in that neighborhood he fixed the trans leak...
On to my quick tranny leak fix....as the fluid in the 6 speed is not under tremendous pressure all you need to do is either try the method that some have described with sucking the fluid in OR, just do what I did, clean the area reeeaaal good, then put silicone sealant along the line where the two end pieces meet, worked for me for over a year...
Hope this helps...ya sou Niko...
Old May 22, 2007 | 04:09 PM
cjcvette's Avatar
cjcvette
bkazepis,
Thankyou for your information. My car is a 6spd.
What brand and type of Silicon did you use?
Old May 22, 2007 | 07:12 PM
Neeko's Avatar
Neeko
I have a 6spd with just over 88k miles. I like your little quick fix with the silicone. At the least that will buy me some time. What kind of silicone did you use?
Efharisto!
Old May 22, 2007 | 08:50 PM
Profit's Avatar
Profit
Interesting.. I also have this leak..
Old May 22, 2007 | 10:15 PM
Neeko's Avatar
Neeko
what exactly am i leaking by the way? What should i fill with?
Old May 22, 2007 | 10:24 PM
cjcvette's Avatar
cjcvette
Neeko,
The trans fluid should be red. Yours sounds more like diff fluid. Can you describe the location of the leak in a bit more detail?
Old May 22, 2007 | 10:38 PM
Neeko's Avatar
Neeko
I cleaned off where its coming from. Its the seam between the tranny and the diff. The fluid is dark purple.
Old May 31, 2007 | 10:09 AM
doubleD's Avatar
doubleD
Default double D
Same problem on my 2000.( original owner ) Had ALL SEALS replaced by the local dealer. $1050.00 but no leaks at all now
Old May 31, 2007 | 10:26 AM
C5_Baker's Avatar
C5_Baker
I'm having the same issue. Luckily mine is still under warrenty, it is being fixed today. The shop said that it would take most of the day to do the work.
Have you ever had the tranny serviced? Purple fluid sounds to me like your trans fluid could be degraded or "burnt".
Just my 2cents.
Good luck with your repairs!
To Tranny/Diff Leak
Old May 31, 2007 | 10:37 AM
corvettebob1's Avatar
corvettebob1
Just a word of caution here, there should be NO OIL in between the trans and diff, so if it leaks there you have a larger under laying problem that needs to addressed ASAP!
Old May 31, 2007 | 10:47 AM
Nyvetteguy007
I agree BUT I think he means the tail end of the trans housing....
Old May 31, 2007 | 10:53 AM
Nyvetteguy007
Efharisto!
um....red?
