suggested valvetrain for this cam.
Old May 20, 2007 | 11:28 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default suggested valvetrain for this cam.
considering a cam swap on my 97 A4. Planning on the thunder racing 220/220 .551/.551 114 LSA. Was told it has excellent power witouth sacrificing drivability on street condiitons.
What valvetrain would best complement this setup?
Also what other engine hardware is needed to complete this kind of swap?
thanks.
Old May 21, 2007 | 05:46 AM
vettenuts's Avatar
vettenuts
Since its a 97, I would install:
LS6 oil pump
LS2 timing chain
New pushrods (hardened)
Upgraded valve springs
New valve seals
Options:
Timing chain damper (if the block is drilled for it)
Yella Terra (ultralight) or Scorpion rockers
Under drive pulley/harmonic balancer
Pin kit for the harmonic balancer
Old May 21, 2007 | 09:57 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
LS6 oil pump
LS2 timing chain
New valve seals
Options:
why the timing chain?
i was going to do a underdrive pulley setup, but i have a high output alternator that doesn't allow for an overdrive pulley attachment (and i need my current) .
Old May 21, 2007 | 10:07 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
The LS2 Timing chain is much stronger than the old LS1 timing chain. Even if you were to go to the dealership and ask for a LS1 timing they will give you an LS2 chain. As for the underdrive pulley Powerbond makes good one for a decent price. Stephen (EnglandGreen) put one on Tom's (Y2kvert4me) car when he installed the cam and it worked great. Hope this helps you out some.
Old May 21, 2007 | 08:13 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Go at least the TR224 114
Old May 21, 2007 | 08:21 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default I agree with phils C5 vette!
I second the TR224 or something similar. The 220/200 is small.
Bob K.
Old May 21, 2007 | 10:35 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
i meant to type 224....I dont' know why i typed 220.
If i were to have a camshaft professionaly installed (with all the nessicary components) what's the price range i'd be looking at?
Old May 23, 2007 | 01:50 PM
phils C5 vette
Have a professional shop install it and tune it. It will cost you between $750 to $1000 dependant upon local prices. If you dont have to have emmissions testing, do the TR224 on atleast a LSA 112. Its a nice little cam
To suggested valvetrain for this cam.
