From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Gear swap...exactly what do I need??
Ok, ordered my 3:42 gears from Gene and just got them today. What are all the parts I need to change for this to work? Here's the list of stuff I think I need according to Mike Mercury's writeup.
1. Gears (got em)
2. Stall TC.....I'm thinking about a yank 3200
3. Transmission cooler.....any suggestions on kind and price?
4. Carrier tranny center shaft seal pn 24228816
5. Seal Plate O-ring pn 12369456
6. Aluminum 6" seal plate pn 12369457
7. Side plate outer "O" ring seal pn 89047953
8. Output shaft(s) center seal pn 88996703 Do I need 1 or 2?
9. Anerobic sealer pn 89021677
Do I need all the above stuff? I bought the whole carrier with 3:42's. Does it come with any of the above stuff?
Thanks for any info. Man, I'm so excited.
jeff
1. Gears (got em)
jeff
There's so many ways to do this sucessfully; that I hope others respond as well.
2. an option - yes. But not mandatory.
3. Yes, if going with a higher stall.
6. Not needed. Your current carrier has this plate already. Just transfer it over (but replace the old seals).
Ah, I'm not sure what you are doing - are you ONE, trying to install gears only into your current pumpkin, or two, did you order an entire rear carrier (pumpkin) that you are going to install??
I ordered the entire pumpkin and received it yesterday. For some reason, I was expecting this huge thing to come crated in a wooden box. UPS came with this small box and I was so surprised to find my pumpkin. lol
jeff
