Changing coolant... DexCool or???
Old May 31, 2007 | 05:08 PM
RB Racing's Avatar
RB Racing
I have also heard of people flushing out the DexCool and using regular anti freeze after.
Old May 31, 2007 | 11:11 PM
Third Gear's Avatar
Third Gear
I haven't personally haven't had any negative results running DeathCool, but it does seems to be very sensitive. I noticed a little bit of residue in my Camaro... some collected on the Coolant level sensor and it had to be cleaned so that "low coolant" light wouldn't go on... I didn't notice too much on my vette.
Someone posted a VERY interesting article in a thread I started on LS1Tech, Page 2. It's a very good read.
http://www.ls1tech.com/forums/showth...7&page=2&pp=20
From what I've heard Prestone Extended Life is supposedly the same formulation as DexCool. The colors are just added. Otherwise all the coolants would be more or less clear.
I MIGHT change coolant... If I do I'll probably go with Zerex G-05 coolant. I think Ford, Mercedes-Benz and a few other companies use it without problems and their engines aluminum/iron/whatever like ours. I think the main thing is change it often...
