Sway bars
Old May 22, 2007 | 02:33 AM
slverc5's Avatar
slverc5
Default Sway bars
Will be upgrading my FE1 to Z51 sway bars that came from a 99. How much do I need to tighten them when installing the bolts. ft/lbs torque.
One other thing, can I reuse the existing rubber mounts that is on the end links- I'm thinking of reusing the end links other wise I might get metal endlinks and get poly rubbers supports for the endlinks.
I do have a torque wrench. Thanks in advance!
Old May 22, 2007 | 03:42 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Dump the plastic endlinks, they tend to brake pretty easy and the new ones are not that expensive. Also, if those Z51 bars are from a 99, they are smaller than the 00+ Z51 bars, in case you did not already know that.
Old May 22, 2007 | 05:14 AM
slverc5's Avatar
slverc5
Yup. I bought them from a CF member. As long as they are thicker than the FE1's I think I'm ok. For $50 shipped I think I bought them at a fair price!
Old May 22, 2007 | 07:29 AM
slverc5's Avatar
slverc5
Anybody on the ft/lbs of torque when tightening the bolts?
Old May 22, 2007 | 08:17 AM
yellow01's Avatar
yellow01
Front:
link nuts 53 lb ft
insulator clamp bolts 43 lb ft
Rear
link nuts 53 lb ft
insulator clamp bolts (upper) 49 lb ft
insulator clamp bolts (lower) 70 lb ft
Send or post your email and I can send a pdf that was post here long ago with all of the key torque values for the C5.
Old May 22, 2007 | 10:08 AM
slverc5's Avatar
slverc5
Sent you a pm!
To Sway bars
