Reduced upper end oiling
Reduced (within limits) oiling is desirable for (at least) two reasons; reduced windage loss due to less oil draining back onto the spinning crank and less oil being pushed out the breather during extended high rpm periods [the change to the internal baffling in GM valve covers between LS1 and LS2 engines likely attests to their recognizing unacceptable breather oiling issues].
If anyone has experience with reduced orifice pushrods in a road racing application I would appreciate your sharing your results.
