G5X3 cam question
Old May 23, 2007 | 08:29 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default G5X3 cam question
Is there any HP difference between the 112 or 114 LSA in LG's G5X3 cam? Thinking of going with that cam...................Paul
Old May 23, 2007 | 09:04 PM
Lynch Z06's Avatar
Lynch Z06
Default g5-X3
The biggest difference is were the power comes in on the RPM band.
Old May 24, 2007 | 01:47 PM
Ls14CamaroSS's Avatar
Ls14CamaroSS
the g5x3 112 will clear but some people go by the .080/.100 rule of clearance and i measured it at .070/.110 so get the x3 on a 112
Old May 24, 2007 | 05:40 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
You have an AUTO, get the 114 No fly cutting and the car runs great. Man I love mine.
Old May 24, 2007 | 06:40 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I have a different motor w/dished pistons,So I'm not worried about PTV clearence.The 114 LSA will probably be easy to tune anyway.Thanks guy's for the replies ..............Paul
Old May 24, 2007 | 09:06 PM
jordanfd's Avatar
jordanfd
Have G5X3 cam with 114. With the 114 and Auto. it is easier to tune. With this cam you should think about a higher stall T/C. Frank
Old May 24, 2007 | 10:05 PM
kilrb's Avatar
kilrb
The 112 will have 4 degrees more overlap, and will be more lopey. It will come on stronger earlier in the powerband, and will probably have a few more ponies up top. I debated a lot about going with a 112 vs. 114 on my 224/224. I wanted the low-end you get with a tighter LSA. With a big(er) cam like the G5X3, the 112 would really be nice, as it's going to be peakier than a small cam. I agree with the others though, that because you have an auto, the wider LSA (smoother idle) might be a good idea...
To G5X3 cam question
