Help: How do I remove the door panel?
(1) you'll need to remove the plastic piece that encircles the interior door handle; to do this, pull the handle forward like you're opening the door, and use a flat blade screwdriver to pry inside the two small horizontal slots in the piece, one above and one below the door handle. Be careful as it is easy to scar the plastic.
(2) there are 5 plastic force fit connectors that hold the panel to the door. These are attached to the inside of the door panel, and they force fit into holes in the door. 3 of them are generally along the bottom of the panel, and the other 2 are just below and above the front door speaker. I found it easier to start along the bottom. Use a butter knife or a couple of small flat blade screwdrivers, and insert them along the bottom of the door panel. You might start toward the rear of the door, at the location where the door panel changes color if you have 2 tone interior, or where there are 2 panels if you have single color interior. You'll find one connector there. Put the screwdrivers on both sides of the connector and pry, being careful because the vinyl on the panel is paper thin. Once you've freed the first one then move along the bottom edge of the panel & you'll find the next 2.
(3) the panel along its top edge has a lip that fits inside the top of the door (i.e., where the window protrudes upward from the door). So, once you've gotten the above removed, then lift the panel out and upward, pulling the lip upward and out of the ridge in the door.
Good luck. :cheers:
