No Backup Lights
Old May 24, 2007 | 01:34 PM
dinows33's Avatar
dinows33
Default No Backup Lights
Got in car today,(2003 roadster 38000 mi) no backup lights. Replaced relay, not the problem. Relay has 5 prongs, When I put the relay almost all the way in and touch the 3 prongs that that are in the same row the test light lights. When I touch the two other prongs on the other side with the test light (which is grounded) the backup lights come on !!! Any Ideas ???????
Thanks Dino
Old May 24, 2007 | 01:41 PM
65GGvert's Avatar
65GGvert
You don't say auto or manual, your profile isn't filled out, so I'll go generic. Only three possibilites, if they light with the fob (approach lights) but not in reverse. Power, ground or switch (manual). Check fuse #21 in passenger foot well (I know, it doesn't say b/u lights). If it's a manual, do a search, I've posted a picture of the switch on the transmission several times. Short across the plug side with power on and see if they light. If so, the switch is bad. I guess you could have a broken wire, but post more information or search reverse lights and try again.
