Question; need answer
Old May 25, 2007 | 06:53 AM
masterbarber's Avatar
masterbarber
Cruising
Default Question; need answer
Can someone please tell me if the tierod ends, idler arm or pitman arm or any front end parts need to be lubricated on the c-5.
Most cars dont any more . Need to know before I aattempt my own oil change.
Old May 25, 2007 | 07:35 AM
TLewis4095's Avatar
TLewis4095
All steering & suspension parts are sealed w/no lube required.
Old May 25, 2007 | 08:21 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Some of the parts you list are not there on a vette. Rack and pinion type. No fittings that I have seen so far.
Old May 25, 2007 | 08:54 AM
newgene's Avatar
newgene
I don't think there is an idler or pitman arm, is there? As for the tie rod ends, they have a black rubber bushing under the nut. There is no zerk fitting, as it is not the boot-type that holds grease.
Old May 25, 2007 | 10:14 AM
rws.1's Avatar
rws.1
no grease zerks on a stock C5 anywhere...
Old May 25, 2007 | 09:01 PM
masterbarber
Cruising
Default thanks,,
thats what i thought but wanted to make sure.
To Question; need answer
