I bought a Sun Visor with the door opener built in but I cannot program it to open my garage door, It looks different than Homelink but I dont know what it is to look up programming instructions does anybody know of other brands.....
If it doesn't have the picture of the house, I don't think it will do rolling code openers. Maybe someone else will knows for sure. When I did my visor I was advised to only use the one with the little house on it.
I programed my Home Link in our Jeep and Toyota. At first I didn't think it worked because I pressed the button just like I'd press it on the wall switch. Try pressing it down for about two to three seconds. That's what works for me. A momentary push of the button won't make it work. David
i just programmed a home link to a rolling code opener. of course you have to have power and a light on the visor-at least mine does.
try this:
hold visor button and opener button on at the same time for 20 sec or so. if you have a light on the visor it will flash when code is set and will flash rapidly if rolling code is required.
then go to the opener and press the "learn" button on the side ,usually red, and the small light will light next to the learn button. you have 30 seconds to push the button on the visor 2 long pushes (2 sec ea) and sometimes a third.
give it a try and if it works, good. if not, try your best to find another way to get the vette out of the garage!
try this:
Going to try this when I get home thanks Now to find the relearn code on the community gate muahahhaaha!
