Center console area is very hot
Old May 27, 2007 | 02:38 PM
max1986weber's Avatar
max1986weber
Default Center console area is very hot
Im a new corvette owner and the center console area is very hot while driving. You can feel very hot air coming out from under the center console and around the shifter area. Its hot to the touch. Is this normal for this car or do i need new firewall?
Old May 27, 2007 | 02:59 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
normal
Old May 27, 2007 | 03:20 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Holy crap you ain't kiddin it gets hot there!,I checked mine one day with one of those laser temp guns,It was 105 degree's inside the center console,I couldn't even leave my hand on it.Over the winter I had the torque tube out,I put insulation all through the torque tube tunnel and covered the tunnel brace and also put insulation underneath the console.Next time I go for a ride I'll check the temp.It did get alot cooler there now,When I touch inside the center console its not that hot,Alittle warm ..................Paul
Old May 27, 2007 | 04:31 PM
Last C5's Avatar
Last C5
Totally normal and the fix is to install a ceramic coated tunnel plate.
Old May 27, 2007 | 09:12 PM
berryj's Avatar
berryj
I did the Elite Eng tunnel plate aluminum w/ ceramic coating. Now they have that plate w/ insulation attached too which would be even better. Also it makes the car more rigid on cornering almost like a sway bar upgrade. Lastly, I added relectix insulation from Lowe's and put it all under the console which also helps.
To Center console area is very hot
