Caliper wont come out
Old May 27, 2007 | 10:13 PM
jor8888's Avatar
jor8888
Default Caliper wont come out
even with a impact wrench I was unable to get both of the caliper bolts to come loose to change the rotor.
Old May 27, 2007 | 10:21 PM
corvettedoug's Avatar
corvettedoug
Use PB Blaster. You can buy it at most part stores. It works miracles!
Old May 27, 2007 | 10:56 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Someone probably used a lot of red locktite on the bolt threads. You may have to heat the bolts and then try to remove.
Good luck.
-RR
Old May 28, 2007 | 01:02 AM
BlackZ06's Avatar
BlackZ06
I'm gonna assume you've already removed the calipers and are trying to remove the black caliper brackets.
Those bolts are torqued to 125 ft/lbs, and also have Loc-Tite on them. Get a LONG pipe to fit over your wrench and use a steady pressure to break them loose. Leverage is your friend in this case ....
Old May 28, 2007 | 05:35 AM
Janster's Avatar
Janster
Are you referring to the larger bolts that holds the bracket?
Impact didn't work for us either - so we used a ratchet w/ extention and a HUGE piece of pipe ( for leverage).
Or are you referring to the caliper pins? Are they spinning?
If yes....take a look at them closer, there are 'flats' to put a wrench on.
Old May 28, 2007 | 11:05 AM
thomastl's Avatar
thomastl
I just took mine off on the rear to adjust the parking brake.
My cheap Sams Club/Walmart Impact would not budget one of the bolts.
My expensive real impact wrench that does 600 ft/lbs in reverse backed it right out.
If you don't have room to get it out w/ a pipe extension - get a good impact wrench from Home Depot or Lowes for about $100.00 that has some real torque to it.
Old May 28, 2007 | 11:16 AM
jor8888's Avatar
jor8888
its the 125ft/lb torque bolts. k I will try the better torque wrench since there is no room to put a longer pipe. thx for the tips.
To Caliper wont come out
