Is this a LS6 intake?
Old May 28, 2007 | 05:45 AM
Brice's Avatar
Brice
Default Is this a LS6 intake?
Old May 28, 2007 | 07:22 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
88894339, 88890524, 88890523, 12561184, 12573572
Here are the part numbers for all the variations of the LS6 intake
Old May 28, 2007 | 07:24 AM
Z06PSI's Avatar
Z06PSI
88894095, 12557846, 12556333, 12561269, 12560688
Here are the LS1 intake numbers
Old May 28, 2007 | 07:48 AM
Brice's Avatar
Brice
Default ...
thanx but the seller can't give me the part number
(the intake is already in the package, ready to ship)
Old May 28, 2007 | 08:15 AM
Z06PSI's Avatar
Z06PSI
Call bull****. Tape doesn't cost that much.
Old May 28, 2007 | 08:19 AM
hpjunkie's Avatar
hpjunkie
No, it is not.
Old May 28, 2007 | 09:16 AM
Brice's Avatar
Brice
Originally Posted by hpjunkie
No, it is not.
thanx!!!
Old May 28, 2007 | 12:10 PM
nlreb54's Avatar
nlreb54
Is there any difference in the variations of numbers? I have found a 12561184 that I am thinking about buying for my 98 A4. Thanks
Old May 28, 2007 | 12:20 PM
MR496's Avatar
MR496
Default ask the guy if the EGR valve is included
If he says there never was one, it is an LS6
Old May 28, 2007 | 12:55 PM
Z06PSI's Avatar
Z06PSI
No variations other than F-bod or Corvette. I think the F-body 01-02 has the EGR. All the LS6 intakes are flat on the bottom.
Old May 28, 2007 | 03:14 PM
rgtkst's Avatar
rgtkst
nope. it has the spots where the tubes went under it. the signs are even on the foam pads. Ls6 does not run the coolant tubes thru under there.
Old May 28, 2007 | 05:46 PM
sugarwolf's Avatar
sugarwolf
Way to tell is the LS6 has square ribbing between the intake ports while early ls1 intakes have large X ribbing. So thats a LS1 not a ls6
Old May 28, 2007 | 07:32 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Default Ls6
Also LS6 intakes are completely flat underneath, they do not have that hump down the middle, that is an LS1 intake
To Is this a LS6 intake?
