oil pressure sensor
Old May 28, 2007 | 11:30 AM
hotparts's Avatar
hotparts
Default oil pressure sensor
Hi guys,
could it be that the oil pressure sensor from the LS2 doesn`t work with the LS1 PCM?
My sensor was gone and i have the LS2 engine in the C5. I ordered the sensor for the LS2 but i don`t get it working.
It always shows the 0522 code.
The sensor fits and looks similar but the whole inside the sensor is smaller then the one from the LS1, but i think this should be ok.
Is there an electrical difference between LS1 and LS2 sensors or do you know if there is voltage on the cabels (with the colors please) so that i can meassure if the mistake is there?
Thanks for your help!
Old May 28, 2007 | 02:47 PM
hotparts's Avatar
hotparts
PLEASE HELP
