Normal Coolant Temp??
Old May 29, 2007 | 05:59 PM
99BlkVette's Avatar
99BlkVette
Default Normal Coolant Temp??
I picked up a 99 FRC and I can't decide if my coolant temps are normal. On a moderate temperature day, my coolant will reach 230 and bounce back to 219 when the fans kick on. I've left my car idling for 30 minutes to see if I could get it to over heat but it continued to drop down to 219. My question is, is this temperature normal? What does everyone else run in their vettes as far as temperatures during the summer time during traffic/ cruising.
In an attempt to lower my temps, I've flushed out my dexcool, ran cleaner through the coolant system and I'm currently waiting for my 160 T-stat to come in. Any comments or suggestions would greatly appreciated.
Old May 29, 2007 | 06:01 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It's normal, and the only way to make it run cooler at idle is to reprogram the fan setpoints.
Old May 29, 2007 | 06:12 PM
Bill Dearborn's Avatar
Bill Dearborn
Everything was normal. The engine is fine with those temps. Once you start moving on the highway at 55 or so the temp should come down to about 195. Without changing the fan turn on the temps will stay the same even with the 160F thermo.
Bill
Old May 29, 2007 | 08:19 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
Bill
Old May 29, 2007 | 08:30 PM
coolz51's Avatar
coolz51
turn on the air-condition and the fans will run at idle which will keep temps under 196*
Old May 30, 2007 | 01:50 AM
99BlkVette's Avatar
99BlkVette
Feww! I thought I might have had a problem. Thanks for all the replys.
2 more quick questions.
(1)Where is the blasted search feature on this site?
(2)What engine managment/ data logger system do people with the LS1 motors go with? LS1 Edit?
Old May 30, 2007 | 07:29 AM
65GGvert's Avatar
65GGvert
Better clean out the debris, grass, paper, whatever, that gets trapped in and between the two part cooling system (radiator and a/c condensor) before you do anything else. Changing to a 160 thermo will just make it open sooner, once it's open the temp will go right back where it was before. The thermostat controls the minimum temp, not max.
Old May 30, 2007 | 08:02 AM
99 vett babycar's Avatar
99 vett babycar
[QUOTE=99BlkVette;
(2)What engine managment/ data logger system do people with the LS1 motors go with? LS1 Edit?[/QUOTE]
1) go up to the top of this page - you'll "find search" in the red banner running across the page
2) LS1 Edit is very good, I prefer HPTuners.
Old May 30, 2007 | 01:21 PM
Pwrtrip75's Avatar
Pwrtrip75
You do not know how many people think this is the other way around.
My 99 FRC runs the same temp also, I was kinda curious.. I knew they ran hotter but wasnt sure.
Old May 30, 2007 | 03:22 PM
hotwheels57's Avatar
hotwheels57
If you can read past all of the chest thumping and puffing, here's the latest longest running discussion...
http://forums.corvetteforum.com/show....php?t=1705311
To Normal Coolant Temp??
