I have a 2000 coupe with 37000 miles on it. Stock automatic.
Today when I got in to go to work, I could not get the window down, doors to lock, mirrors to work, memory .... nothing from the control panel on the door. I have had a compustar 2W900FMR on the vette for 2 years. It works just fine but will not lock the doors.
Turn the switch on, hold down the power down window button and reach into the hinge area of the door and wiggle the accordion like black rubber assy. If the window starts to work, slide the rubber back and disconnect and clean and tighten the two connectors that connect the door electronics to the car. Don't take the door panel off to do this, it's in the hinge area with the door open. Post what happens.
