active Handling code 1287
Old May 30, 2007 | 09:47 PM
xosepy's Avatar
xosepy
5th Gear
Default active Handling code 1287
I was getting a messeger on the dic for active handling service soon , took it to the dealer for service and one hour later part & labor $570.00.
Over the Holiday I search the forum for this problem and one thread read, check the air on the tires. I went to check and all four tires had difference reading(from 31 psi to 27 psi).correct air pressure to 32 psi, and guess what, problem is fix. I want to thanks the forum and the menber who help me. thank you
