Gas mileage
Old May 31, 2007 | 05:21 AM
vetteman51's Avatar
vetteman51
7th Gear
Default Gas mileage
I have a 97 C5 which I was getting around 25-26 MPG on a trip. I changed the gears to 3.43 and put in a new torgue converter. Now I get about 16 MPG on a trip. Is this normal or is something wrong?
Old May 31, 2007 | 05:30 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
How big of a stall converter did you put in ?? and do you mean 3.42 gears ?? I would guess that it sounds a little low--but it could be something else--Did you have a tuner make all the appropriate computer adjustments associated with a hi-stall torque converter ?There are some things that MUST be done to make it work right
ie: TQ management-shift times-misfire detection-trans pressure-shift point adjustments(related to the 3.42)
Old May 31, 2007 | 06:54 AM
99 vett babycar's Avatar
99 vett babycar
once the stall locks up it has nothing to do with your mileage. It is not unusal to drop 20 - 25% when you go from 273's t0 342's but your drop seems a little larger than normal. I went from 30mpg t0 24mpg highway but I've got a lot of mods also. Have you had your car tuined??
Old May 31, 2007 | 08:24 AM
robert123's Avatar
robert123
It is possible to get that mileage in city driving , but you should be doing better on the highway.
Old May 31, 2007 | 10:16 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Did you put the new gearing in on the ECM? My mpg change was negligible. 2 mpg at most.
To Gas mileage
