St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Issues after header/ cat install. Please provide feedback?
I finally got my Kooks 1 3/4 headers, HF cats with xpipe and connecting pipes installed. I broke the oil temp sensor and the coolant temp sensor connectors off. Below is a breakdown of the issues, please tell me if this is normal or not????????????????
Thanks for the help in advance
1) CODES
PCM
P0118 C
P1637 C H
IPC
B1543 HC
SCM
No Comm
RFA
U1096 H
U1064 H
U1016 H
Coolant temp reading shows xxx F on the DIC and the guage pegs at 260 F until I reset the PCM codes
Oil temp reads low on the DIC
DIC message "SERVICE ENGINE SOON" appears when I shut the car off
I guess the only thing that really bothers me is that coolant temp gauge although I know the connector is unplugged it still bugs me to see that high temp LOL
1) CODES
PCM
P0118 C
P1637 C H
IPC
B1543 HC
SCM
No Comm
RFA
U1096 H
U1064 H
U1016 H
So are the sensors fixed/replaced?? If not I would start at that then delete the codes.
