Battery Post Disconnect
Old Oct 24, 2001 | 12:05 PM
VetteVert's Avatar
VetteVert
Default Battery Post Disconnect
Will I cause any problems using a battery disconnect, and disconnecting it after each time I take it out? It is usually weeks between. Will anything freak out being reset that often?
TIA
VV
Old Oct 24, 2001 | 12:51 PM
Purerock105's Avatar
Purerock105
Default Re: Battery Post Disconnect (VetteVert)
The radio. Make sure you have the 4-digit code to unlock it, or you'll be calling
your dealer to call Chevrolet to get you one.
My battery died, went and got another battery, put it in, cranked the car and
everything was good to go...except the radio. 'Code, what code?"
it's explained in your owners manual. :)
Old Oct 24, 2001 | 12:53 PM
carpe dm's Avatar
carpe dm
Probably not, but you know how touchy this car is to electrical stuff. Why don't you get a battery tender? Much better solution, as the battery will stay in top shape and you just have to hook it up and forget it with complete peace-of-mind! :D :smash:
Old Oct 24, 2001 | 01:26 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Re: Battery Post Disconnect (carpe dm)
I agree with carpe dm. Get a battery tender. Better yet, if you need a new battery anyway, get a Optima yellow top and forget about it altogether.
By the way, check your e-mail. I sent you a e-mail about your PRTs.
Old Oct 24, 2001 | 01:45 PM
VetteVert's Avatar
VetteVert
Default Re: Battery Post Disconnect (98-C5)
Any battery is going to drain over time, so I don't think the Optima will gain me anything. My current battery is in good shape. I may look into a battery tender. I also replied in your post :)
Old Oct 24, 2001 | 03:44 PM
2kbluestreak's Avatar
2kbluestreak
There was a post about a year ago from a guy that had a mid-year being stored in his garage for the winter, probably with a battery tender. It seems that a positive wire someplace shorted out, causing a huge current flow, causing a fire, that burned up his Vette and garage. If anyone thinks there is the remotest chance of this happening to their car, be it a C5 or earlier, then the smart thing is to disconnect the positive wire and wrap it with insullation, or completely remove the battery. I now do this with my 30 year old summer queen. :yesnod:
Old Oct 24, 2001 | 03:55 PM
Fast one's Avatar
Fast one
Default Re: Battery Post Disconnect (2kbluestreak)
I removed the battery twice last night and only had to reset the clock; my radio must not be locked.
Old Oct 24, 2001 | 05:10 PM
Purerock105
Default Re: Battery Post Disconnect (Fast one)
Yea, you can turn off the 'theft-lock' option. Or in your case it must have never been turned on. Mine's off now :lol:
To Battery Post Disconnect
