Wheel and Tire Question
Old Jun 3, 2007 | 12:36 AM
FRC Jon's Avatar
FRC Jon
Default Wheel and Tire Question
Not sure if I am beating a dead horse or not on this....but I just purchased and picked up a set of stock Z06 wheels and tire sizes...are there any fitment or size issues I need to be aware of with this new combination. or are they straight bolt on. Also, what is the wides tire that is recomended for the stock rears..... They look to be a lot wider than the stock thin spokes for my y2k FRC....TIA,
Jon
Old Jun 3, 2007 | 12:40 AM
Mudvayne387's Avatar
Mudvayne387
Sorry i dont have an answer , but what did you do with the thin spokes you have on now ? i may be interested
Old Jun 3, 2007 | 12:49 AM
rws.1's Avatar
rws.1
Z06 tires and wheels are a direct bolt on for a standard C5.
IF i remember correctly 285 width is the max for stock wheels
check out tirerack.com
select tires by size
type in a 275 width and check specs it will show the rim width range
do the same for 285 and 295
The answer will be found in the presented details
Old Jun 3, 2007 | 12:54 AM
FRC Jon's Avatar
FRC Jon
Thanks RWS, thats what I thought but just wanted to make sure...Mudvayne, check your pm's there is a message for you.
Jon
Old May 7, 2008 | 08:20 AM
TMRoc's Avatar
TMRoc
Default Wheel size ?
What is the widest wheel I can put on a stock c6 rear without the wide body conv. kit?
Old May 7, 2008 | 08:27 AM
VinnyT's Avatar
VinnyT
I want to say 295's, but I think someone has done 305's.
To Wheel and Tire Question
