Only the third brake light works
Old May 6, 2008 | 06:12 PM
stormrider's Avatar
stormrider
Default Only the third brake light works
I just replaced my brake light switch down by the brake peddle but my main brake lights are still not working. The hazard lights, turn signals and tail lights all work just not the 4 main brake lights. Anyone have any suggestions?
Old May 6, 2008 | 09:54 PM
stormrider's Avatar
stormrider
Somebody?
Old May 6, 2008 | 10:00 PM
bcartman2's Avatar
bcartman2
try holding your turn signal slightly up and down and see if you get anything, i have seen the turn signal switch cause the main brake lights not to work, the 3rd light is operated off of a seperate switch, redundant system...
Old May 6, 2008 | 10:44 PM
stormrider's Avatar
stormrider
/\ thanks for the suggestion but no luck the brake lights still will not work
Old May 7, 2008 | 07:50 AM
stormrider's Avatar
stormrider
Bump
Old May 7, 2008 | 10:32 AM
jovette's Avatar
jovette
suggest you check your grounds on the rear brake lights
To Only the third brake light works
